Cheapest Water Cooling Setup
firewolfsm
1,848
29
So...not the best thread...but, what are the parts for a set up like this?
My main concern is price, then silence, then performance. I need to cover my single graphics card and processor. Hopefully it can still have thermalright ultra-120+ performance.
aigomorla
21,087
3,598
case? are you knowledgeable in modding?
I think you could probably pull something off for around 250-300 which would be very decient.
Thats assuming you mean your cooling your 7900GT.
firewolfsm
1,848
29
Yeah, 7950GT, actually, I should update that.
and a Raidmax X1, not really made for water cooling but there's a lot of room in it.
and I have some experience with mods, some metal cutting, soldering, etc.
aigomorla
21,087
3,598
i already started piecing one system out for another topic member.
You need to think of ways to mount the large class radiator. I would think a top mount, or a external rear mount would work.
Look at jab-tech for RADBOX for a rear external mount. But becareful in how you mount it or you could block your DVI output on the 7950GT.
http://forums.anandtech.com/me...=2128648&enterthread=y
