Good Day.
I'm currently in need of a PCIe Small Form Factor video card that supports 3 monitors and doesn't use a lot of power.
The reason for Small Form Factor is because this is going into a Lenovo M58 SFF workstation that I use as an admin box.
Because I am using CentOS 5.7 x86_64 as my OS, I prefer nV over AMD as I am having a hell of an issue with getting CCC to run, and the OS UI Driver Settings doesn't even have a triple monitor setup option.
Also, if all 3 ports can be digital, that would be even better, however, don't sweat it if you can't find it.
Even better would be for 2-3 of them to support 2560x1600 as I may end up getting a couple 30 inchers at some point for NOC monitoring.
Any help would be appreciated. Thanks.
