Cheapest thing I found so far is over $65, and it don't seem to work very well.This cable will not convert Y, Pr, Pb to RGBHV
Nope, only a ethernet jack, and the custom cable jack for the output.I thought the old Xbox had a composite output on the back? Doesn't it?
It has composite output on the back, you just need the right cable to plug into the jack, like this one. As for converting component to DVI or VGA, there's no cheep way to do that.
No, my bad. here's one for the original xbox.A 360 cable works on the original xbox ?
