zCypher
Hi everyone,
Looking for the smallest possible desktop system for someone. Doesn't need to be ultra super duper mega powerful, but should be at least E350/4GB or equivalent. I'm thinking that a prebuilt system *might* turn out to be the best deal, and those will definitely be considered since the computer is not going to a techie type that cares about whether it was prebuilt or not. The best dollar/performance value in a small form factor is the idea here.
Here's what I'm looking at so far:
Motherboard with E350, $84.99
http://www.newegg.ca/Product/Product...onn-_-13186212
Antec case, $58.99
http://www.vuugo.com/en/Micro-Towers/Antec-ISK-300-65-Mini-ITX-Desktop-Case/ISK-300-65.aspx
RAM is cheap, so I'd probably just stick 8GB in there for $35 like I did with my computer. I'd like to go ssd+hdd but honestly, for the usage it probably wont matter if it just has a single plain hdd whatever i can find for under $100.
Where I'm really unsure is the power supply. Any recommendations for good quality power supplies for this kind of build?
ps i'm also considering this gigabyte motherboard instead of the foxconn: http://www.newegg.ca/Product/Product...YTE-_-13128468
More expensive but it has USB 3.0, a PCIE 16x slot, just seems better overall. we'll see! open to recommendations on the board of course
Antec case, $58.99
