What is the cheapest pre-built PC I can buy -- or what kind of specs would it have -- that would allow me to play Bioshock Infinite at high or max settings? Thanks.
What resolution?
Just built a rig recently for $650 with an i5-3570k, GTX 660 and it played the game maxed out at 1920x1200. So I guess pick a cheap intel/amd chip (i3/Celeron G1610 or FX8350) and slap on a good video card (GTX 660 or ATI 7870 at least).
Chip = 125
Mobo = 75
GPU = 175
HDD = 100
Case = 50
PSU = 75
Around $600 but can be considerably less if you jump on the hot deals.
What resolution?
Chip = 125
Mobo = 75
GPU = 175
HDD = 100
Case = 50
PSU = 75
no a GTX 660 (non-Ti) will not allow him to run full settings.
When someone asks for full settings... i assume closest to 60fps as possible, unless they mention 3d.
OP... you want to get as close to 60fps as possible...
the lower you go, the more choppy / shutter it will appear as you play the game.
That puts you on the 7970... A 660Ti will do it... however the system that guy linked is not the Ti.
Again... if ur super tight on budget... look for a prebuilt system arround the 7970, (Intel or AMD) wont matter if the system comes with a 7970 GPU card.
