Cheapest Component Out Video Card for a Mame Box
austin316
3,572
What video card can output in component out with good quality at a lower price?
thanks in advance.
Matthias99
8,808
Also, all RADEON 8500 and RADEON 9500 and higher cards have component output if you buy the adapter from ATI. I don't know how the prices compare to a 6200 with component output.
YOyoYOhowsDAjello
Moderator<br>A/V & Home Theater<br>Elite member
Aug 6, 2001
31,205
45
The adapter is about $30. I'm using one on my 9800pro and it's working wonderfully.
The 8500 takes a VGA to component adapter while the 9500 and above uses a DVI to component adapter I believe.
eelw
10,348
5,497
Why would you need component out for Mame????? A RF connection would be fine for those graphics.
austin316
3,572
Originally posted by: keeleysam
So he could use his HDTV
no no no. I would be using a 20" SD tv. Everything I have read though is that you have to use at least s-video, but component would be ideal. Have I been mistaken?
Matthias99
8,808
I doubt you'll see any difference on an SDTV -- they can only display 640x480, interlaced.
Component would be better, but probably not much better than S-Video. Certainly not enough to buy an expensive new video card for.
austin316
3,572
Ok, then new question. what card is the cheapest that will do excellent tv-out via s-video?
JonTom
311
Matrox G400 Max was the last of the GREAT Matrox TV out cards. Matrox cards aren't cheap anyways, so onever mind that.
Volari is a great choice for HD output. Probably also for SD svideo.
GF4MX is a good cheap choice for SD svideo out.
