Cheapest box I can build?
plagiarist
323
I need to set up a replacement electronic loom control PC, basically it needs to run windows 98 or 95 and operate software that interfaces with an electronic loom, the 75mhz system that was doing this before is no longer booting. Obviously this needs to be done on the cheap.
Basically I need the lowest cost barebones system possible, and on top of that possibly a low grade wireless G card so it can also have web access in that part of the house for streaming audio.
ANy tips?
D
Deleted member 4644
If you are willing to use used parts, I suspect you could find a bare bones system (and/or parts) for $150ish in the for sale forums.
Prebuilt, you might be looking at 300ish.
The advice from Inlinefour is also good.
halfadder
1,190
The best overall value is a $299 bundle from Dell or your local big box stores, you'll often find a Celeron/Sempron, 512meg, 80gig, CD-RW/DVD-ROM combo drive, 17" flat glass CRT, printer, scanner, modem/ethernet bundle for $299. You might be able to build something for a similar price, but a prebuilt will include Windows, which is about a $80 value.
InlineFour
Banned
Nov 1, 2005
3,194
