Originally posted by: JAG87
Originally posted by: Baked
Let me guess, you're not a member of head-fi forums, because everything you said is against head-fi's motto.
I am a member, with the same handle as here.
That doesn't mean I spoon feed myself all the bullshit that comes out of that forum. I re-cabled my HD650 because I wanted a long durable braided cable, not because it sounds better.
Originally posted by: Sadaiyappan
OK will this:
X-fi sound card
improve sound on my laptop?
Somewhat. It will be better than on board sound, but if you truly want to get immaculate sound, you need a usb DAC, plus a good quality amplifier, depending how much power the line out of the DAC puts out. Try the DAC first, then get an amp if needed. For high volumes, you will most certainly need it.
Originally posted by: hans030390
Ok, so with this theory, all car speakers don't need an extra amp. Since basic speakers can easily be powered by the amp in my headunit, I don't need another amp for higher end component speakres, right? Same for my subwoofer? The all have the same resistance. So then why does this NOT WORK?
Some drivers, headphones or not, just need more power regardless of the resistance.
That said, though, I don't think the OP needs an amp in this case. Maybe if he wanted to get the most out of something like the Denon AH-D2000, but these don't need it.
WTF?
Speakers NEED amplification (unlike headphones). The amp in your head unit is shit. Grabbing the pre-amped signal from the head unit and using a high grade dedicated amplifier will OBVIOUSLY result in better sound. This is a completely different scenario than using a pre-amp signal to drive headphones. A pre cannot be used to drive speakers, so i dunno where you're going with this.
Originally posted by: darkswordsman17
Amps are built into just about everything with a headphone jack. But since you're probably meaning dedicated amp we'll go with that. Impedance does not tell you if you need an amp or not. By your logic the AKG K1000 shouldn't need a dedicated amp, as they're 120 ohm, but they're notorious for needing speaker amp levels of power to get driven well. Also take for instance the new Denon's. They have boomy, uncontrolled bass when not given decent amplification, and they're only 25 ohms I think.
You say an amp can't improve the signal, and you point out that you can improve the amp, which is what dedicated amps are intended to do. Tell me, what do you think is probably the better amp, the one with its own regulated power supply or the one built into a the chip that procesess audio, serves as both DAC and ADC, and is built into a motherboard? Not only that, but it is possible for the amp to make it more sonically appealing, which is what people are actually looking for.
There are a ton of factors that play into amp quality that you don't touch on (slew rates, bandwidth, etc), and you completely ignore that some headphones need different types of power. Some are more current hungry, and others voltage. Trying to simplify it to impedance is very naive.
All that being said, I personally am not a huge proponent of dedicated amplification (especially when it comes to cheap ones or ones that tend to have significant shortcomings which most portables do), and find DAPs, receivers, and computers get a lot of undeserved trashtalking, but its not like dedicated components don't make any sense. Personally, I recommend spending more and getting better headphones or maybe a better source (although I feel there's plenty of undeserved source trashtalking as well). There's a lot more to this subject, and I don't mean to derail the thread, just wanted to make a counterpoint.
Two things determine if you need an AMP. Impedance and Sensitivity.
Sensitivity (or efficiency in dB per watt) is something that is quite standard across headphones, and with the exception of a few such as the K1000s (thanks for bringing it up), it does not vary much. Almost all headphones are well above 90 dB with some reaching 100 dB.
Resistance on the other hand varies a lot between headphones. A headphone with 32 ohms of resistance will sound a lot louder than one with 300 ohms.
Anyways I don't know why we are jumping hoops, an amped signal will ALWAYS be worse than it's pre-amped signal. That was my original point.
