- Aug 25, 2000
- 148
- 0
- 0
This one is a little involved, so if you're not comfortable wielding a soldering iron, you better leave it alone. If you are, then for $2.75 you can get a nice little thermal monitoring kit on close-out from:
computernerd.com
It was made to monitor the temperature of a Socket 7 CPU, but can be modded to monitor almost anything with this hack (by yours truely):
bunkerMENTALITY
It plugs into your joystick port (with a pass-through) and then displays the temp of what ever you stick the thermistor to on the screen. You can add a second thermistor and monitor two things in your box (hard drive, videocard, northbridge, cpu heatsink, whatever). The hack is quick and easy and the thing actually works very well.
computernerd.com
bunkerMENTALITY
