Cheap do-it-yourself ultra quiet fan mount
Spike
6,770
Seems interesting but kinda ghetto. I just used 120mm fan silencer kit which basically has two 120mm rubber "cups" to put between your fans and the case as well as some rubber washers. This worked marvels for vibration noise and does not leave rubber bands hanging out the back.
Still, they get an A+ for simplicity and cheapness
-spike
Mucker
2,833
That is pretty inovative Garlic, however, are you a Jeff Foxworthy fan?
m :)
Nessism
1,619
I'm sure the rubber band trick will work fine but it's not likely to last too long; rubber will start to crack after a while. Just not sure how long "awhile" is?
Garlic
Banned
Dec 28, 2004
447
