Cheap and quiet PWM fans?
drizek
1,410
I just got a new motherboard loaded with 4-pins and I want to upgrade my case fans on my antec solo. I want to switch out thev 120mm tricool in the back and add two 92mm in the front, as well as possibly replacing the 120 on my zerotherm CPU cooler. Basically the benchmark for noise is the tricool on low. It's already a bit loud for me, so I want something quieter than that(under low stress) but that can also put out the same cfm or more than the tricool on high(regardless of noise).
I've seen some that fit my needs but they are very expensive. Is there anything out there that comes in at under about ten bucks a fan or so?
Dec 10, 2005
28,886
14,147
I put two Arctic Cooling PWM fans (F9 and F9 Pro) on my Hyper TX3 and have been very happy with their noise-level. Very quiet and they have PWM sharing, so I could plug both into the one 4 pin connector on my board.
drizek
1,410
Thanks. Seems like a good option. The two 92s and one 120 pro came out to 30 bucks. Does anyone have any other recommendations or should I pull the trigger?
And can anyone comment on whether it is worth replacing the stock zerotherm cooler? It seems to work well enough, but more airflow never hurts. Edit: the zerotherm puts out slightly more cfm than the ac fan, and since it is plenty quiet, I won't be replacing it.
alizee
501
drizek
1,410
Thanks, I got my Arctic Coolings today though. They are pretty quiet, but they don't report the fan speed. It's kind of a weird setup and I think I've installed them incorrectly.
Dec 10, 2005
28,886
14,147
I have mine daisy-chained to the CPU-fan slot (both are on my heatsink). One fan reporter is connected to the end of the chain, and I can see that speed. The other is connected to a motherboard header and it just says N/A in my BIOS.
drizek
1,410
oh ok, that makes sense.
I cut the daisy chain stuff off of my 120mm... I'm going to have to get out the electrical tape :)
Dec 10, 2005
28,886
14,147
It's PWM sharing. If you don't daisy chain, you just attach the 3-pin fan monitor cable to the open end.
drizek
1,410
Ya, I didn't realize that when I cut it. I ust don't get whey they would go through all that trouble of sleeving the cable only to have that stuff hanging off of it.
