Axonn
For people who don't know the HAF-X: it has lots of openings & grills: including a large fan AT THE TOP.
Ok so my logic says that I should leave the fan on top because it sucks more air from the chassis and throws it out, improving case cooling. But if I do this, the PSU might not get ideal cooling.
If I install it with the fan down, then it will pull only SOME air from the case, but most air will come from outside the case, since the case has a grill on its bottom allowing for airflow.
So, what do you think? Should I install it with the fan up or down?
