Originally posted by: JSFLY
I dont think its possible to charge a dead battery by plugging it into itself.
Originally posted by: Mermaidman
ROFL!
Perhaps they meant from cig lighter of another car?
Originally posted by: Wapp
Text
huh?
the op said a device you plug into the cigarette lighter, not plugging your car into itself..
lol
Lets analyze the sentence. First, lets drop the unnecessary part from the beginning:Originally posted by: JSFLY
my sister says she saw a commercial for some device that charges your car battery through your cigarette lighter.
Wording ambiguity...
Originally posted by: Zenmervolt
They exist. And theoretically they work. At least, well enough to give you one or two cranks if your battery isn't really very dead.
However, it is risky at best to do this in a modern car given the number of microprocessor-controlled pieces, some of which may not tolerate current flowing in reverse very well.
Jumper cables are still the best.
ZV
Originally posted by: Pacemaker
Leave your cell phone plugged into the car charger then turn off and on the car several times. It will drain the battery on your cell phone (it does do it on my car, but others may have systems to stop this).
My dad is a mechanic and he doesn't see a problem with them besides the fact that they are only good for one start if the battery/charging system are truly gone.
Edit: Note: Your cell phone cannot start your car.
Edit2: Even if it is fully charged.
Edit3: Even if you bought the really long lasting battery.
[*]Some device charges your car battery through your cigarette lighter.
Hmm, seems clear to me that an external device does the charging, but lets go further. The last part is also not necessary:
[*]Some device charges your car battery.
Is it clear now that it is an EXTERNAL device that charges the battery, and not the lighter that is charging the battery? Since it is clear, there is no ambiguity.
It is poorly worded, but it isn't ambiguous. I think the problem stems from you extending a lesser used definition of "through" to mean more than it does. Your first implied item does not say what item is charging the battery via the cig lighter. "Through" does not correctly mean the cig lighter is doing the work.Originally posted by: Mermaidman
Possibly implied items:
Car battery is charged through cig lighter.
A device is used to do this.
Said device not specified as the charger. It could simply be a conduit.
Ambiguous speech FTL.
the commercial shows a woman opening her glovebox and then plugging this battery pack into her cigarette lighter which then starts her car after a bit.
