- May 22, 2012
- 6,425
- 292
- 121
Depending on the issue you may be able to read the code yourself. Sometimes you need to be able to view real time data in order to isolate the problem. Also some codes are historical, but not yet severe enough to set a Check Engine Light. If that is the case, some low end scan tools may not show them or do live data.
