Originally posted by: SuperSix
And I believe (If it's an auto) that it needs Honda-specific transmission fluid.
Depends on the year. Honda didn't start to spec ATF Z1 untill 1996 (95 for some of the early CVT transmissions), if i recall. 1995 and below can use Dexron III. Original Honda ATF before Z1 I believe was just honda formulated Dexron IIe. You can use Dexron III in newer cars, however, you'd have to add a HFM (Highly friction modified) additive, because Z1 itself is a highly friction modified fluid, whereas dexron III is not. Lubeguard makes an HFM additive.
Some people have used the Z1 in 95 and older transmissions, with no ill effects, however, I have it to cause slipping in my brother's 94 civic auto, so i used Chevron Dexron III and all is well. I may switch to Mobil 1 synthetic atf or redline or amsoil.
