Changing the FSB: Where and How???
tolemac
26
:|I've got an IWILL P55XB2 w/ 166MMX and Award bios. Am able to increase cpu setting and voltage, but how do I change the FSB??
Tried using SOFTFSB, but it doesn't recognize this board :(
I've gotten it up to 188mhz, but it won't go any further, yet I know it can go to at least 233mhz HELP!!!:confused:
IaPuP
1,186
how did you get to 188 without changing the FSB???
You would probably be able to get 188 if you changed the FSB to 75MHz (up from the default 66MHz).
Read the overclocking guide @ BxBoards. It is fairly comprehensive and informative.
Updated Overclocking Guide HERE
Eric
toph99
5,505
i am assuming u have just been changing the multiplier settings for the cpu?
tolemac
26
Eric...
Thanks for the site! Very Cool :)
I forgot to mention that on my board there is a jumper call T75.
It just must mean 75mhz! ( I am an idiot!) It also has a setting called RSV. Got any idea? I'm going to try adjusting the voltage (I have it on auto right now) and see if that helps. Can't change the multiplier on this chip and bios is no help except for Cas and Ras. Thanks again!
tolemac
