HI I did a home made water cooling system and it work like a charm on my , p4 2.8E(800FSB)* Socket 478 and my 9800 PRO graphic card...
But I'm changing my computer for an Athlon 4400 X2 and a Geforce 7800, so my point is is there any way I can adapt my GPU and CPU coolder for my new rig..
I use
mcw50 for my GPU http://www.swiftnets.com/products/mcw50.asp
and the http://www.swiftnets.com/products/mcw5000.asp# for my CPU
I see there is an adapter part at the buttom but its for the 6800 and for the Athlon 64 not X2.
I'm not shure if its going to be okay for the CPU sicne its socket 939 and for the graphic card to...
did you guys got some info about this ... because I dont want to tuch something that work perfectly.. and dont want to remove tubing and stuff...
And for the GPU since I will remove the big coling fan on it should I add some little memory coling thing..
I use
