JonathanYoung
I will be attempting my first brake pad replacement job soon, and there is something that I am still unsure of after doing my due diligence and research. Should I remove some brake fluid from the master cylinder before starting, or bleed the calipers when I turn the piston back in?
Every Honda service manual/PDF that I've seen says to just remove some brake fluid from the master cylinder so that when I turn the piston back in the fluid can just get pushed back.
During my research, I watched a video by EricTheCarGuy. Instead of removing brake fluid from the master cylinder, he clamps off the brake line with a vise grip (softened with fuel line), attaches a bleeder tube and soda bottle, and lets the brake fluid bleed into the bottle as he turns the piston. He says that this way the master cylinder won't get tainted with dirty brake fluid. (link: http://www.youtube.com/watch?v=nMcqrb64wa4)
I tend to agree with Eric based on the logic of not contaminating the master cylinder. But then, the official word from Honda says that this is not necessary. I'm thinking this is one of those cases where real-world experience trumps the textbook.
So, how do you guys do it?
Edit: Forgot to mention that this is a relatively new car with 18k miles, an '09 Acura TSX. My car has the prematurely wearing brake pads that were the basis for a class action lawsuit. 🙁
Finally got it done this past weekend. I did end up extracting a tiny bit of brake fluid with a turkey baster, but it was a very small amount. I had more trouble with removing the caliper pins and pin boots, as they seemed like they were stuck together. Once I figured that out it was smooth sailing from there.
Thank you guys for your help.
