- May 11, 2006
- 413
- 21
- 81
I just built a new computer (not the one in my signature) and have the following problem...my system tries to boot to the optical drive. After the intitial boot screen, a message pops up saying "no ide device". If I press F1 it will boot to the HDD. In the bios, the optical drive is set to master and the HDD to slave. I cannot find a way to change this. I was thinking that maybe the jumper on the optical drive is set to master, but there are no markings on the pins and nothing in the manuel regarding the subject. The IDE cable was installed correctly with the slave plug in the optical drive and the master plug in the HDD...and on that subject, would it be better to use two cables to connect the two devices? This is a very small Aria case so more cables would need to be worth a performance boost.
