I've got a burnt hardrive that dosen't spin, I'm going to try the freezer methode to hopefully get a back up.
Here's what I've got.
One IDE cable with Master (DvD player), Slave (CD Burner). That burnet hardrive was the master on this chain. My plan is to take the DVD Player out and put a DVD burner in, disconnect the CD burner and set the DVD burner to master.
First off, Can I do this with just unpluging things and changing the jumber on the drives?
I will back up and delete as much as I can from my 30GB drive to leave space to immediately copy my files over to.
Then I will take the burnet drive and freeze it. By the grace of god just maybe it will work and I can put it on that IDE cabble with the DVD burner as the slave. (I've just heard that this should be the slave for some reason)
Do you think this will work? Again what it does is not spin and makes musical beeps. I've heard nothing about these musical beeps. They are not clicks, because it repeats itself perfectly like 5-6 times and they sound musical.
The big thing I need to know about is the MASTER/SLAVE issue. Is it just a matter of changing the jumpers on the drives or is there more to it like software tinkering or something?
Thank you much
Mongoo
Thank you much
Mongoo
