I emailed Ken (the maker of SetiQueue) about this a few months back. It basically turns off some of the built in checks, like to see if the max WUs has been entered at some stupendiously high amount, like those who want to queue more than 800 WUs
Actually some guys in white coats come to your house and give you a nice tight white jacket that is designed to protect your arms very well because it keeps them really close to your body. Also you get some good drugs
What else do you have to do besides change INSANE=TRUE to get a larger cache?
I've been resorting to cutting and pasting WUs to a different folder to keep some in reserve. Only problem doing this is those WUs are going to get very "stale".
<Actually some guys in white coats come to your house and give you a nice tight white jacket that is designed to protect your arms very well because it keeps them really close to your body. Also you get some good drugs >
True , but you bang your head more often when they keep pushing you!
If your Q is just there for 1 user, I find it's easier to just manipulate the setting for min-max Queue size. That allows a maximum of 20 days worth at your current production levels. For multiple users however, the override min-max settings are useful because they can apply to individual users.
Max, i believe that the 800 WUs per user still applies, even when you change the min/max queue depth of the whole program.
The feature was, IIRC, implemented by Ken so that it would do some checking, and so that it stopped the queue from downloading thousands of WUs for one user if they are not needed.
Exactly Confused. With a 230 WU/day average, with a minimun queue depth of 7 days, I should have about 1600 WU's available. It's always stopped me at 800. Changing to INSANE=TRUE has helped a little bit, but I'm only about 860.
I had already restarted it after changing the INSANE value. I just now stopped it, changed the min/max values, then restarted it. I'll see if that boosts the queue level.
This post is a little dated now. I've been trying to post to the DC Forum since early this morning and only just now have I had any luck.
_____________
I think ConfusedBW is mostly correct. Once before OrangeKid told me to get a change you make in the INI and other things to work you need to shut down the Q and then restart it.
A computer restart is not necessary but I've always found restarts to be helpful in many ways. So I'd reboot for the benefits that it provides but it may not be necessary to get the Q to accept the changes. Just shut it down and restart it.
Wow Indy no wonder I was having trouble getting units.
I can see it now.... this is berkley... We are fresh out of work units they are being crunched faster than our virgins can role... oops that's cigars... mean while on the front lines, Indy still is crunching wildly but has this PieDude on his a$$ pulling units almost as fast.
