Hi
Just received my Samsung 214T monitor. And it is very nice!!
I have my desktop computer connected to the DVI connection, and my laptop connected to the VGA connection. Both signals work fine. However, when I start in DVI mode, and changes to VGA it is fine. But when I change back to DVI signal, the monitor goes to Power Save mode or somthing like that (power led flashes) and I can't get any picture. I can change back to VGA mode, with no problem. If I start in VGA mode, I cannot change to DVI mode.
To solve it, I have to reboot my desktop computer, and make sure that the monitor is in DVI mode.
If the laptop (VGA) computer is not connected, there is no problem, as I can't select the VGA mode.
I read the following the the Samsung FAQ section:
Is the monitor connected using the DVI cable?
You may get a blank screen if you boot the system before you connect the DVI cable, or disconnect and then reconnect the DVI cable while the system is running as certain types of graphic cards do not send out video signals.
Connect the DVI cable and then reboot the system.
This might explain it, but there must be some solution to this?? - help!! 🙂
I have a PowerColor All-In-Wonder 9800 card on my desktop.
I does properly not matter, but my laptop uses ATI 9700pro.
