On the back of Dell there are two 92mm fans placed next to the heatsink. I checked the specs on those fans and they are rated at 150CFM, 6k rpm, and 57dB. However in my computer the fan speed is controlled such that if you put your hand next to the fan you feel not much air movement, noise is also not an issue but I am thinking if there is a better solution. The issue here is that I cannot monitor the CPU temp or the fan speed, so if I replace them with a quieter fan that possible have a lower air flow rate, how would that affect the cooling? Can someone give me some advice?
