I am working on a roll-out project of 100+ pcs with 2 images on them. Win xp Hosting Virtual PC. The biggest problem I think will be that the users will accidentally press ctrl-alt-del instead of the host version of it for the virtual pc image. I would like to take the host pc, and make CTRL-AL-DEL not work, but some other sequence work. The pc is running novell client as well, so disabling the ctrl-alt-del in windows is not the correct solution.
Thanks!
Thanks!
