I'd like some best alternative suggestions on this problem.
After some hard times, I finally got a good setup of WINXP home on my machine. The problem is, drive A is the floppy, drive C is my zip drive, drive d is my cdrom, and drive E is my boot/files/programs drive. I researched and found prodedures to change "E" to "C" but the consequences can be a real pain for all my loaded programs. With "E" as my operating system drive, I've already experienced problems with dowloading program updates and drivers for my scanner because they are keyed to seek drive "C". I've also had problems accessing some secure sites because the site checks encryption strength (128) through the "C" file system and finds my system lacking.
What is the best move - (1)change E to C and try to get all my stuff working again that is now loaded on E, or, (2)start from scratch (format "E"), reload XP with my zip drive disconnected. I assume XP will then load to "C" as the hard drive is designated for the setup process. After, I can plug in the zip drive.
My past horror story trying to load XP makes me a little gun shy of starting over again. Which is likely to be the most painful, option (1) or option (2)?
Thanks for all, Jim Johnson
