What he said.Originally posted by: radioouman
dexron is tranny fluid. You can get it anywhere, lol
Originally posted by: morkus64
Question editied:
Ok, so it's the power steering belt. Consider that's like a $6 part, how difficult would it be for me to change myself? I'd rather not give $15 (for "diagnosis"), +$$ for the part at an inflated price, +$$$ for labor to Sears Auto.
Question editied:
You have the 1.6L or 1.8L? I have a '95 1.6L and while I haven't changed the PS belt yet, it would be a pain to do. The alternator is the outside belt of the three. At minimum you will need to remove the alternator belt. The PS might actually be the 3rd belt so you'd have to remove the A/C belt too. And the A/C and PS belts are both down on the side of the engine...not as exposed as the alternator belt which was easy to do. If you're mechanically inclined I'm sure you can do it, but otherwise go take it in because you don't want to screw up the belt tension. IMHO if it is the 3rd belt you might as well replace the other two if they aren't fairly new.
Question editied:
thanks for the info, how much should they charge for replacing it?
