Changing 4870 Fan Speed by default?
Shaitan00
99
I recently purchased a 4870 (VisionTek) and while I love the card it does get insanely hot when left with the stock cooler and default fan speed.
I've been doing some reading and found out how to change the Fan Speed by tweaking the profiles in Catalyst:
- Create a profile
- Edit the profile to set it to manual with a specific fan speed value (want)
- Load the profile
But from what I am reading the custom profile needs to be loaded/selected on boot each time (manually). Is there a way to set a custom profile by default on startup?
Also - is there an easier way to change profiles instead of going through catalyst control everytime (like something on my desktop I can double-click or something?)
Any advice / help would be much appreciated.
Thanks,
Nov 26, 2005
14,946
279
1 My profiles are reloaded every time i boot. Say I shut off with fan at 80% when i reboot or boot up again, its at 80%
2 If you use the tray icon, you can select the fan speed by selecting the corresponding profile. Real easy stuff
Thread starter Similar threads Forum Replies Date
I Graphics Cards 45
ASK THE COMMUNITY
