Changing 2 front tires instead of all 4? Also where to go?
VinylxScratches
So winter is coming up. My two front tires are bald. I COULD NOT Rotate them because back in college, one of my tires was slashed so I got a used tire on the back. I would like to get two new tires on the front. Is that ok? Where is the best place to go? I think wal-mart only charge 7.50 for alignment and I saw pep boys and other places charge 70+. But I may have read it wrong.
My car is front wheel drive btw.
If you're getting snow tires, put them on all four ends unless you want your car to swap ends. 😛 How much snow are you dealing with?
I would put snows on all four corners. But my parents and sister always put them only on the front.
that is a terrible idea. you want your tires to be the same types on all four corners, otherwise you will have different handling/grip characteristics, which will cause unstable handling when you need it the most.
Faclepalm.
Tires should match per axle. You can have different on the front and rear.
Faclepalm.
You can, yes...but you're talking drastically different grip levels front and rear. Not something I'd want to deal with on my car. RWD, you'll be compromising braking and steering. FWD, you'll likely be risking drastic oversteer (assuming snow tires on drive wheels and all seasons on the others).
I've got different on my car now and have none of those issues. I have had different many times.
I'm talking about street cars, not race cars. It will make very little differance for the majority of street cars.
so you're saying having a set of summers on the front but winters on the rear wouldn't be a bad idea? (or vice versa)
Are you driving in snow?
I'm not disagreeing. People without much means cut corners where they can.
You will get alot of oversteer in snow leaving all seasons on the back of a FWD car.
probably not... unless you are driving around in like 6 inch snow.
I generally agree with the logic, but wouldn't two tires with better traction on the drive wheels be better than no improvement with the old tires?
I live in Texas, so I often just buy a set of front tires for my FF vehicles. It would seem altogether less practical I suppose if there is the need for consistent traction on ice/snow though.
Yes I did last year. We had a 100year snow storm in N.VA/DC. i.e. several feet of snow. My RWD CTS was going by a pile of FWD cars that kept getting stuck.
I have some basic kuhmo all seasons on the front and DWS all season (with snow pattern) on the rear. Its one of the reasons I like DWS a lot.
My SiLs Audi A4 has the DWS on the front and some basic tires on the rear. Here car also did well in the snow.
You're not going to have the braking or turning capability you could have if you ran snow tires all around, but I'm sure you know that already. 🙂
snow tires all the way around is best
What happens if you put tires with the most traction on FWD vehicles, the back end is light and does 'come around' as suggested. People put the best tires on front so it pullls better but they should go on the back to keep you from spinning during braking.
Yes it does matter even with daily drivers.
I can't, my two back tires are different age and wear! Can I get by winter with changing two front? Why can't I??
Of course, you can. You shouldn't do it however as properly explained here by desy.
Sears had a very good video about this scenario. Let me find it and I'll link.
