Changin Mobos - Going from MSI Neo2 Platinum to DFI NF4 Ultra-D
peleejosh
1,521
Do I need to do a format and clean install of windows? Or can I just uninstall old mobo drivers and install new ones? I am running XP sp 2.
Slaimus
985
Since they both use the same nForce driver, you should be okay. Update to the latest NF4 standalones before upgrading. They install fine on NF3.
theMan
4,386
^^ it should be fine, if there is a problem, you will notice right away, like a BSOD before windows boots up. i dont think that will happen
The Pentium Guy
4,327
I hate to sound like an annoying idiot, but be sure you have a PCIexpress card :eek:.
peleejosh
1,521
OK thanks everyone. LOL Pentium guy, yeah I have one on order. Meanwhile i have a pci card for backup.
