changes to FSB on my 7N400 Pro has not effect, I am at 1100 MHZ on my amd 2500 HELP PLEASE!!!!
milldakill
42
I just put together my computer today and when i change the FSB on my motherboard, the giga-byte 7n400 pro it does not change the MHZ. my motherboard's FSB is set to 166 and the ratio is set to normal (11 i think is what the normal is) and i cant get past 1100mhz, I am kind of a noob at this so i might be doing something dumb, the board also has dual bios so maybe i am screwing that up but plz plz plz help me, going nutz here
3sixes
101
There is a little blue switch just below the northbridge and above the agp slot, change the setting.
Iron Woode
31,252
12,777
Originally posted by: milldakill
you are the smartest man alive thank you very much, problem fixed
I guess checking the manual was out of the question?
When in doubt, check the manual.
3sixes
101
milldakill
No prob, good to hear thats resolved, however do yourself a favor and spend some time with the user manual, It will help you to know what youve got.
pspada
2,503
There's a reason techies say "RTFM"
