I just received my new XP-1600+ CPU and it is an AOGIA stepping. I want to run it on my Shuttle AK31A (rev. 3.1) motherboard.
I took out my Duron 700 (unlocked and running at 6 x 150 =900mhz @ 1.85 volts) and replaced it with the new 1600 (Still locked). The system would not post at all, so I did the following:
1) Tried to cold start while holding down the INSERT key (Still no boot Post at all)
2) Shut down, switched off my surge protector, removed the battery and switched the CMOS jumper for about 7 minutes (Then got long Beep, long Space, long Beep, long Space, for up to four beeps with still no Post)
4) Shut down, switched off my surge protector, removed the battery and switched the CMOS jumper for about 2 hours (Still got long Beep, long Space, long Beep, long Space, for up to 4 beeps with still no Post)
5) Shut down, switched off my surge protector, removed the battery and switched the CMOS jumper over night
6) Switched back to my old Duron (Still got long Beep, long Space, long Beep, long Space, for up to 4 beeps with still no Post)
7) Restarted and got one long Beep only (Still got long Beep, long Space, long Beep, long Space, for up to 4 beeps with still no Post)
8) Restarted again and finally it posted and displayed the much desired CHECK SUM ERROR, DEVAULTS LOADED message.
Also, now when I kill the power with the ATX switch on the power supply, if I do not turn off the surge protector, when I switch the ATX switch back on the PC starts up again. If I turn off the surge protector and turn it back on, the system does not restart when I turn the ATX switch back on. Very Weird.
Thanks in advance for any comments on these happenings?
