- Oct 10, 1999
- 744
- 0
- 0
Ok heres the scenario.
I bought this STEP cooler, but they are useless and wont' answer my calls.
Heres how the hs/f is setup on my cpu
CPU-(one of those things that moves heat from one location to another)-Two Large socket heatsinks - two fans on top.
its a p3 slot A chip. So picture it if you can.
the two cpu fans died, so i took them off and Put one big case fan in the middle of both the socket heat sinks. Will this work better, worse, or about the same?
