Originally posted by: fleabag
I'm pretty sure the life indicator is based upon a fixed mileage like 5K miles or something..
Some of them are also based on opacity qualities of the oil. I think this is what Honda is doing. My mother has an 09 Accord bought in June and it has this, which it monitors by shining a light through oil at one point in the filtration process and using that to determine need for change.
Frankly, since additives are a concern along with oil contaminants...I'd just use the ole mileage method regardless. My vehicles get their oil changed every 4000mi or 6 months like clockwork, whichever comes first.
Most are calculations based on environment (via intake air temps, etc.), driving style, starts, stops and mileage.
This.
For a CR-V, the OP will be perfectly fine just following the % life remaining display and changing the oil when the display says so rather than based on mileage. I go by the "service" light on my Volvo and my father has had several recent vehicles (2 Ford Explorers and 2 Honda Pilots) that went over 200,000 miles without any problems and he has always just used the % life remaining indicator. No harm is going to come of using the display rather than a fixed mileage.
ZV
Originally posted by: Possessed Freak
Regular intervals has worked for the past 100 years, no reason to stop now.
Originally posted by: brblx
how many cars with with 7500 mile oil changes have you seen with oil sludge problems? 'cause i've seen lots.
preach about the wonders of science all you want, regular (read: 3-5k on conventional) oil change intervals aren't an old wives' tale.
Originally posted by: Analog
Title says it all. My new CR-V uses a %Oil Life indicator. My old Pontiac didn't, and I changed the oil at regular mileage intervals. What do you trust?
volvo's service indicators are straight mileage to coincide with 7500 mile dealer services.
if you want the car to be well cared for and are using dino oil, change it every 4-5k tops.
older volvos had 5k maintenance intervals. your light comes on every 5k.
you're using perhaps the worst example possible to prove your point. i've replaced plugged oil traps on multiple five cylinders that had maintenance records for 7500 mile oil changes. at that interval, you're lucky to get 50-75k before it gets stopped up and the crankcase pressure goes positive. $600-800 repair at the dealer. double that if the passages inside the engine get plugged and the oil pan has to be removed. seen that with 7500 mile intervals, too.
believe whatever you want, but don't misguide other people with that crap. 7.5-10k oil changes are great....for rental cars. otherwise, quit being a cheapass.
This affects my 2.4t? How much is the cost to desludge?Originally posted by: Zenmervolt
The PCV system is a known design flaw on the T5 engines. It should be de-sludged every 60,000 miles. It is precisely the sort of design fault that Marlin mentioned. The PCV system on the Volvo Turbo 5-cylinders will accumulate sludge regardless of the oil change interval. I run full synthetic and there was still sludge in the PCV system when I had it serviced this spring.
ZV
This.
ZV
