Change HAF 922 to Blue LED Fan?
Forte
As the topic says, has anyone successfully changed the fan of the HAF 922 to one with a blue LED as opposed to red?
CM does sell blue led fans in the correct size to fit the 922....But you'll loose the ability to turn the led off/on with the switch.
