The third stage of garage door opener market uses a frequency spectrum range between 300-400 MHz and most of the transmitter/receivers rely on hopping or rolling code technology. This approach prevents perpetrators from recording a code and replaying it to open a garage door. Since the signal is supposed to be significantly different from that of any other garage door remote control, manufacturers claim it is impossible for someone other than the owner of the remote to open the garage. When the transmitter sends a code, it generates a new code using an encoder. The receiver, after receiving a correct code, uses the same encoder with the same original seed to generate a new code that it will accept in the future. Because there is a high probability that someone might accidentally push the open button while not in range and desynchronize the code, the transmitter and receiver generate look-a-head codes ahead of time.
