chaintech vnf4 video problem
alien42
12,844
3,277
my buddy just build a new rig using this mb with a 6200 vid card. everything boots up and is running but there is no video signal to the monitor. i tried my 6600gt and the same thing happened. the video card is getting juice as the fan powered up when i tried my card.
any ideas?
alien42
12,844
3,277
Originally posted by: GadgetBuilder
The VNF4 requires a PCI-e video card. Are the cards you tried this type? What type of PSU?
both the 6200 and 6600gt are pci-e. the 6600gt works fine with my a8n sli board. the psu is also the same psu i use and it is powerful enough for sli and it powers everything up on the new machine so i really dont think that is the problem. i am really leaning toward an issue with the mb.
homercles337
6,340
How do you know everything "boots up and runs fine" without a video signal to confirm? How do you know it will even POST without video? Do a minimal install (psu, 1 stick of ram, video, outside of case) then see what you get. If you POST then repost here and tell us what you get.
MajorPayne
238
I would DEFINITELY say that your motherboard is dead. I had a Chaintech VNF4 Ultra, and it was working fine until my power supply went. I moved to a new PSU and case, but the board would never respond after that (when I powered up, I got power, drives spun up, but I never got ANY video at all, and no beeps).
Nothing I did would get video out of it. I finally wound up trying another video card (still no video, etc), different RAM (same result), CPU (nothing different here) and different PSU's (still no go). Only when I replaced the motherboard did everything work again.
Part of the issue I had with the Chaintech board is that when it is dead, it acts like it is just a video-card issue, when it is in fact the motherboard that is the problem. It gives no error beeps, and aside from literally trying another 939 motherboard (not an easy extra to get if you are like me), you may never be able to tell what is wrong with it.
Before you RMA it, I would check that the ATX and 4-pin connectors are connected, and that you have no extra motherboard mounts shorting it from behind, but what you have sounds EXACTLY like what I had when my VNF4 died. Since you know the videocard works, and I presume that you can test the RAM, if you can verify the CPU is good too, then you can definitely say the board is dead, and send it back. Good luck.
