Chaintech VNF4 ultra sound in windows not work please
rhrg32
9
Hello
i m from brasil
sound sistem windows xp professional not work??
but cd,mp3 ,divx,avi and anothers works fin sound
please helpe me
GadgetBuilder
148
I use the Realtek audio driver from the CD that came with the VNF4 and it works fine in XP SP2 Home.
It is also possible to install the nVidia sound driver instead but I haven't tried it because I'm happy with the Realtek driver.
Which audio driver did you install?
rhrg32
9
Realtek ac97 from cd not work and nvidia nforce nvmixer not work too
in windows but cd,avi,etc work fine
GadgetBuilder
148
Can you leave the nVidia audio driver out and install the Realtek from the CD?
What CD drive do you have and what interface - IDE/SATA? Do you have multiple optical drives?
Did your XP installation go smoothly? Which nVidia drivers are you using? Is XP running normally except for audio?
What happens when you go to Device Manager, select DVD/CD-ROM Drives, double click the CD drive, click Troubleshoot and follow the procedure?
Try inserting an audio CD and then run Realtek's AVrack. This should bring up a list of songs on the CD. What happens if you try to play a song using AVrack?
