Hi all, and thanks in advance for reading/commenting.
Bought the Chaintech VNF3-250 and Athlon 64 3200+ from Newegg. I've built literally hundreds of PCs and have never had the problems I'm experiencing. I am unable to load Windows XP Pro. No matter what combination of hardware I use, I'm stopped at the STOP Error 7e or 7d (which seems to be a hardware error) during the "Detecting Devices" phase. Here's a list of the things I've tried:
- Swap Kingmax DDR500 modules purchased for this machine with a known-good Corsair DDR333
- Relax memory timings/increase DIMM & CPU voltage.
- Disable all onboard devices (can't disable NIC)
- Disabled IDE controller and tried to load XP off of a Highpoint Rocket100 controller
- Low-level format hard drive
I've tried the fix floating around the 'Net involving the disabling of the secondard IDE controller and changing the CDROM to Slave, still no-go. Seems like most people are using at least one SATA drive on this board. I'm using a PATA Seagate 160GB drive and a Toshiba 16x48 DVDROM drive. I've tried loading the nVidia IDE controller drivers for XP (copied them off of the driver pack to a floppy and loaded them as a SCSI device, F6 in XP setup) still nothing. Tried a beta version BIOS floating around, but it wouldn't even boot the hard drive so I switched back to the official.
I'm at a total loss, machine components listed below. Swapping the PS next, but any other thoughts?
Thanks,
-Evan-
Case: Antec Sonata
Board: Chaintech VNF3-250
Processor: AMD Athlon64 3200+ w/Zalman CNPS7000A-Cu Cooler
Power Supply: Antec TruePower 380w (known good)
Memory: 2x512mb Kingmax DDR500
Video: Matrox G450 16mb
DVDROM: Toshiba 16/48x
Onboard Sound/NIC
Thanks,
-Evan-
Case: Antec Sonata
Onboard Sound/NIC
