WelshBloke
- Jan 12, 2005
- 31,363
- 9,234
- 136
Yeah, you keep using the system King George told you to use.The United States is a world leader, not a follower.
By GOD almighty we do not have to conform to what the world expects.
Um, try the late 60s / early 70s, kid.![]()
If the metric system is superior because it uses base 10, why don't we divide our years and days into units of 10? Why not 10 months in a year, 36 or 37 days in a month, 10 hours in a day, 10 minutes in an hour, 10 seconds in a minute?
What no one here is considering is that while the imperial system is never as elegant as a base 10 system like metric, it is oftentimes far more practical.
WRT to time, the obvious answer is that is makes a ton of sense to divide your day into 720 (or 1440) units, because you can evenly divide those numbers by 2, 3, 4, 5, 6, 8, 9 10, 12, 24, 36, 48. What can you evenly divide 100 by? 2, 4, 5, 10, 20, and 25? Oh, that's handy!
It's the same with length and volume measurements. 12 inches in a foot makes it easy to divide a foot into two (six inches), three (four inches), four (three inches) or six (two inches). Two cups is a pint, two pints is a quart, four quarts is a gallon. Very easy to double or halve volumes.
Note: That's not aways useful. For example, I think for bolt sizing, metric, or any base 10 system, makes a lot more sense. Because you want nice even steps up in size.
Why change? What problems does it solve? I'll admit I'm not up to speed on what difficulties using a system other than metric adds. Does it increase the cost of commerce? Cause rounding errors in some obscure system somewhere that will cause a nuclear plant to meltdown?
Yeah, you keep using the system King George told you to use.![]()
Republican hero President Reagan eliminated the metric conversion that Presidents Ford and Carter started which proves that forcing metric on everybody is unamerican.
We have a very high tech brake in our shop that cost hundreds of thousands of dollars. They are only made in Europe and so it only accepts metric units. My guys in the field are typical Americans and measure stuff in inches, our plans are in imperial and so our the shop drawings. It costs money for my guys to convert every single measurement into metric before they start running metal. Then there are mistakes, which are always bound to happen, every once in a while in the conversion which costs more money.
That's just in my relatively very small field of work.
You want to sell the metric system to the American people? Tell them that they're not some 300 pound fatass, they're a scant 136 kilos. No, you don't have a small 5 inch penis, that thing is damn near 13 centimeters. The metric system is the vanity sizing of the measurements.
lol +1
The shop at one employer had a saying - you design it to a 32nd of an inch, we'll mark it with chalk and cut it with a torch. Thankfully the machine shop had a different philosophy, so when it had to be precise, it had to go through the machine shop.For one shit like this won't happen anymore.
http://www.wired.com/2010/11/1110mars-climate-observer-report/
$125M satellite plus the cost to launch the damn thing to mars went splat because we refuse to use the same units as the rest of the world.
And yes it does cost industry time and money to use both systems. We have a very high tech brake in our shop that cost hundreds of thousands of dollars. They are only made in Europe and so it only accepts metric units. My guys in the field are typical Americans and measure stuff in inches, our plans are in imperial and so our the shop drawings. It costs money for my guys to convert every single measurement into metric before they start running metal. Then there are mistakes, which are always bound to happen, every once in a while in the conversion which costs more money.
