Cha1 Fan Speed to low?
b3six
98
i flashed the bios to 1006 and i got this at the startup.. when I checked it in bios the fan speed said 0 rpm so i flashed it to the bios on the disk.. it still says 0 rpm.. what is the cha 1 fan?? and is there another way to check if its working?
edit: I can see the CHA2 fan on the mobo but I cant find the cha1 so i cant see what is connected to it.. on a asus a8n sli deluxe anyone know where it is?
GuitarDaddy
11,465
It if for a chasis fan, you probabally don't have anything hooked to it. You can stop the message by setting "Stop on no errors" in the boot settings menu
Regulator07
517
in bios, go to hardware monitoring, and under after the q-fan settings, there is an option to turn cha1 fan monitorng off, do that and you are set
b3six
98
ah thx for replies :) i looked around case and found the cha1 connecter was hidden under some wires in the bottom right of the bored with nothing connected to it :)
thx agn! :)
