Enclose the variable name in quotations, a la:
<cfif "FORM.select_#index#" neq "">
Alternatively, you can address the FORM variable as an array. The following would be equivalent:
<cfif FORM['select_#index#'] neq "">
As a third option, which is useful when you don't know exactly how many options you'll have, loop through FORM.FIELDNAMES and test whether the left n characters are what you'd expect them to be:
<cfloop list="#FORM.FIELDNAMES#" index="i" delimiters=",">
<cfif Left(i, 7) eq "select_">
<cfset index = GetToken(i,2,"_")>
<!--- process your info here, with i being your actual form field name and index is now the index number of that field --->
</cfif>
</cfloop>
I use this method most often, I think, as when I end up having dynamic form field names, I typically don't know exactly how many I'm going to have. In addition, they may not always be numbered continuously from start to finish. If you start skipping, your script becomes either very inefficient or will error out.
Edit: Also, make sure you use <cfqueryparam> whenever you are sticking dynamic content into your queries (or use stored procedures). There was a SQL injection exploit for ColdFusion a couple months ago that was very bad. I'd hate to see it come up on anyone.
