I bought a Dell i6000 with the 2.0 GHz Centrino processor. When running on the battery, the System Properties shows 798 MHz. Great, however, when I plug the power cable back in it remains at 798 MHz. I've used the Dell QuickSet controls to select "Maximum Performance" but it won't clock back to 2.0 GHz. I have to restart the machine with it plugged in before it will again run at 2 GHz.
Is there a certain way to get it to *always* run at ~800 MHz on battery and 2 GHz on A/C?
BTW, this is the case even under extreme processor usage.
