JEDI
How to Make Your Air Conditioner More Effective and Efficient (lifehacker.com)
Before doing anything else, Radziej says you should check your thermostat to make sure the blower fan is on, because it helps circulate cool air, giving your AC unit a bit of a break. “Just think about it, it’s constantly circulating air from the basement up to the second floor and back down,” he told Fox 9. “It’s the most efficient way to use it.”
WHAT?!
is this true?
WHAT?!
is this true?
