the wiring has good contact (one of the wires was taped up from a while ago and I re-did it to make sure it's still good).Originally posted by: Cattlegod
check the wiring to the fan. possible you blew a fuse or a connector came loose.
also smell it, if it smells burnt you may have to replace your fan.
Originally posted by: rh71
the wiring has good contact (one of the wires was taped up and I re-did it to make sure it's still good).Originally posted by: Cattlegod
Could it be a motor problem with these symptoms (the buzz sound) ?
