Cellular: difference between CDMA and GSM?
Krassus
Two local providers offer similarly priced phones and plans. But one is apparently CDMA and the other GSM. What's the difference? The CDMA provider prices the phone i want (Motorola v60) a little higher, but has far better plans.
Basically with GSM, you get a small little card which plugs into your phone, and that's what your account/phone number is locked to... which means you can change your cell phone as many times as your want, as long as you use that same card then your number wont change...
With CDMA however, your account/number is locked to the actual phone (no card)... so it will be more different to change phones (will have to notify and go through your carrier)...
GSM is also what's used in the rest of the world (Europe, Asia, etc)... So some of their phones will be compatible here and vice versa (not all though, since GSM has different frequencies too).... CDMA is only used in North America...
That being said, GSM in North America is relatively new compared to CDMA... so the CDMA network might be more extensive and offers better reception... This depends on the carriers in your specific area...
Hope that answers some of your questions...
CDMA = Code Division Mulitple Access.
TDMA = Time Division Multiple Access.
IIRC GSM is the next generation of TDMA. GPRS (General Packet Radio Service I think) is tied to GSM and that is the methof of data transfer. The current generation of CDMA offers faster data rates and will most likely always outpace GPRS and its new iterations.
