Cell Model Biology Project -- HELP!!
MrCodeDude
13,674
I have to make a model of a cell for Biology and I would like to use something like clear hairgel for the cytoplasm. Problem is I need about a gallon of hairgel (it's a big model, 12"x12"x6"). Any suggestions or home-made recipies? Note: The substance has to be stable at room temperature (can't require refridgeration).
Thanks!
-- mrcodedude
Wallydraigle
Banned
Nov 27, 2000
10,754
Unflavored gelatin maybe if you make it a little on the thick side? It might still melt, I don't know. Although I have seen some cheap hair gel in like quart tubs before that was clear adn colorless, if you could find that it would be easier maybe.
JACKHAMMER
I will say agar again, and hey your teacher might even have some to spare. Depends if they still pour their own plates or not.
mchammer187
9,114
ever seen "there's somthing about mary" very easy to "make" your own
dunno about a gallon tho ;)
anyways that gelatin idea looks like it might work
