Bill Kunert
I have a MSI 694T Pro board which has Tualatin support. I had a PIII-700 running at 1.01 GHz. In order to defeat the bus speed selection and run at 133+ instead of 100+ MHz I had to cut a trace on the board. I just installed a 1.3GHz Celeron and it wouldn't boot. I reconnected the trace and it runs ok up to 115MHz(1.495GHz). Above that I run into agp bus speed problems. Apparently Intel is monitoring the bus speed selection lines for a short period after power on to make sure the lines aren't cut so another means has to be found to force 133MHz as the default processor speed. Anybody got any ideas?
Thanks
Bill
Thanks
Bill
