Celeron Tualatin 1.4Ghz Load Temp of 51 degrees C?
Mullzy
352
I just picked up a Celeron Tualatin 1.4 and am surprised at its load temperature. I'm running it at stock specs with the stock hsf configuration. Either gaming or running a CPU load util I can easily get to 51 degrees Celcius. I haven't let it cook steady for 3 or 4 hours to see if it will get any higher. I don't have a case fan atm (just the psu fan is moving air) so my system temp hovers around 36 degrees celcius.
I'm going to add a case fan this weekend and hopefully drop 5+ degrees off my system temp, but I'm not sure if it will have any impact on the high load CPU temp. What's the *normal* load temp for a Tualatin 1.4 Ghz? Forgive me if this is trivial, but I thought I'd seen several posts here in the past with people running Tualatins at < 40 degrees (using better hsf configs, but nothing you can't buy at any pc shop). I thought some of the nicer hsf setups would drop 5 degrees for you, but not 10-15.
Input, suggestions? Thanks!
EDIT: Oh yeah I forgot... It idles around 45 degrees (after it's been heated up nicely). This morning I turned the PC on and immediately started a CPU load util. System Temp was still around 28 degrees C when the CPU hit 48 degrees. I shut it off and went to work before it could hit 51, but there was a full 20 degrees difference between CPU and Sytem temps.
Mullzy
352
OK thanks, it seemed high but I wasn't sure if I should be concerned.
My power supply fan isn't really moving a lot of air... well at least compared to my old C850 system case. Maybe a good case fan will help a ton. If not, I'll try re-seating my heat sink I guess.
oldfart
10,207
Make sure the HS is not on backwards. The notch lines up with the raised part of the socket.
Assimilator1
24,174
525
Maybe your mbrd measures cpu temps via the internal thermal diode? ,if so then it'll show higher temps & react quickly to loads.
Either way though your case temp is on the high side ,fit that case fan;) ,also make sure your PSU fan is exhausting air ,some don't!
And yes lowering case temps will also lower cpu temps as a result
Mullzy
352
Just an update...
I popped in a case fan and dropped my case temp down to 25c depending on room temperature. My CPU still hits around 48c under load, but I do notice the temperature climb immediately as you mentioned. So maybe the temp I'm finding for my CPU is different than the standard people are using here?
For example:
- Idling my system temp will be about 25c, CPU around 43c
- I start running a CPU load program and the CPU will hit 45c in about 10 seconds, 50ish in around 2-3 minutes.
I tried using MBM to monitor my fans/cpu temp, but I couldn't find a sensor which would read the same as my bios (or the gigabyte mobo util). The highest MBM sensor temp I could find was around 38c (higher than my system temp but lower than my bios CPU temp). Is this maybe the sensor which is a better indication of temperature? In MBM I never found something that said "CPU Temperature", just 3 different settings all something like VIA234235 (completely made that up).
Do maybe I am looking at the internal thermal diode temp.... hopefully.
ugh
2,563
Just got a 1.3 Celeron as well. Using it in a not so well ventilated casing and the temp was like 51C idle. Haven't had time to do any stress testing. Using a MSI 815-EPT Pro-R mobo. Not sure if it's using an internal diode to measure the CPU.
BTW, anyone has any luck OC-ing a 1.3 Celery?
oldfart
10,207
Originally posted by: Mullzy
Just an update...
For example:
That sounds normal. You are fine.
Assimilator1
24,174
525
These Celerons generally top out at around the 1.4-1.5GHz area ,some hit around 1.6GHz!:Q:D
Mullzy
Re MBM ,have you checked out MBMs site to see which setting you need to use for each sensor?
Also you may need to use some sensor 'compensation'
oldfart
10,207
I've had (3) 1.4 Tuallys and all of them went to 1.6 @ default Vcore. One would go there undervolted to 1.35. The other two I never tried. 1.7 is usually where the ytop out.
Assimilator1
24,174
525
Wow!:Q ,I guess the latter ones do much better then:)
Most peoples reports I've seen say they can't hit much more than 1.5GHz
oldfart
10,207
That was on the early 1.0 - 1.2s. 1.4 ->1.6 @ default or less Vcore is a given. I dont think 1.7 would be very hard. The newer lower clocked CPUs are also doing well.
Assimilator1
24,174
525
Wierd ,I must of had a bad cpu then as it wouldn't go above 1.46GHz (133FSB) & I know the RAM & mbrd are good for 145FSB.
vcore is 1.55v ,I guess it could of gone a bit higher with higher voltage but I didn't try.
oldfart
10,207
Yeah, it always a gamble. I never tried a 1.1. I like the 1.4s since 1.6 is a given, and they come with a bigger HS/F. I've put them in as upgrades in BX boards. The lower FSB is good to keep the AGP closer to spec.
ugh
2,563
Any of you guys here use the thermal pad that comes with the CPU or do you apply AS2/3 on it?
alkemyst
83,769
19
Many times it's the other components not the Tualatin that's limiting....
51C is high regardless...I am at 33C case and get 41-42 at load with a slk-800, on my pep-66t 45 would be a high.
alkemyst
83,769
19
I would say case cooling doesn't hurt. I have a quiet set up with 5 case fans. I am using Power PC and Cooling's 80mm silencer's now and it's nice.
ugh
2,563
I've retried my 1.3Ghz Tually. It's idleing at 51C and my case temp is 47C. Argh... Don't know how it got so high. My other machine's case temp is only 32C and the CPU temp is 43C. This rig needs SERIOUS cooling....
Assimilator1
24,174
525
Jesus thats high for case temps!:Q
Hottest I ever had was 42C & that was mid summer ,with a room temp of mid 30's & before I had 2 case fans.
