Please don't run Celerons on Via chipset motherboards.
The Celeron in itself isin't the greatest performing chip, combine it with the poor memory performance on all Via boards and you have a system better suited for your dogs use.
Seriously, Via chipset motherboards sap around 100-150MHz as compared clock to clock to a BX board. This means the same CPU can be run slower on a BX board and still perform the same. BX boards generally allow you to overclock a given chip higher(AGP card allowing) so you get a double poor performance whammy. More bad news for Via is it's UDMA/66 support is generally slower then a UDMA/66 drive hooked to the UDMA/33 port on a BX board, but hey, don't listen to me - read Anand's articles and look at the benchmarks and make your own conclusions if you dare. - M.
