Celeron II on BH6 overclock - need voltage adj on slocket?
Slickone
6,120
If I get a 566 or 633 and o'c to 850 on my Abit BH6 Rev 1, do I need to get a slocket that has voltage adjustments on it? I found a generic one real cheap w/ no adj. Yay or nay?
Toro 45
4,263
You might be able to get by with a cheap one since your BH6 has voltage adjustments in the Bios but I would'nt recommend it.Don't skimp on the slotket get a good one like the MSI MS-6905 Master.
A cheap slotket can greatly affect your overclok & possibly hold you back.Also on my BH6 I could only go the 1.70volts with the slotket votage set to default.I had to raise the slotket to 1.65 as a default which then gave me higher adjustments in the bios up to 1.9 volts.
Toro
